Ansys Learning Forum Forums Discuss Simulation General Mechanical Calculation to the end with errors Reply To: Calculation to the end with errors
harshvardhan.negi
The NCNV, 1 command is for "Terminate the analysis and the program execution if the solution fails to converge (default)".
If you wish for the calculations to continue, try NCNV, 0.
More information can be found here: NCNV
I hope this helps.
Harshvardhan
Ansys Help
Ansys Learning Forum (Rules & Guidelines)
