Ansys Learning Forum › Forums › Discuss Simulation › Fluids › The total mass flow rate in DPM model › Reply To: The total mass flow rate in DPM model
November 4, 2024 at 9:42 am
The inlet (flow) mass flow is not linked to the DPM (injected) flow directly. If the DPM model isn't coupled the particles have no effect on the carrier phase flow.Â
So, if you increase the injection mass but don't have coupling then there will be no effect on the flowfield. As we track parcels you'll also not see any additional tracks.Â
