Ansys Learning Forum › Forums › Discuss Simulation › Fluids › turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 640565 cells › Reply To: turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 640565 cells
November 4, 2024 at 9:39 am
I'd avoid odd shapes around a wing as you may trigger unwanted mesh resolution due to the curvature. Check defeaturing relative to smallest cell size. The check is to warn if you're trying to mesh to a greater resolution than you are simplifying the geometry to.Â
