Ansys Learning Forum › Forums › Discuss Simulation › Fluids › turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 640565 cells › Reply To: turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 640565 cells
Hi Rob,
Thank you very much for your reply.
I did not check by changing the number of iterations. However, I changed the case with low velocity (10 or 30 m/s) and the simulation gives reliable results.
I do have another question about meshing. Please advise me if I have to post it separately in another thread.
When going for a fine mesh, or increasing the domain size, I am getting the following error,
“The specified defeaturing tolerance was found to be larger than a specified size. The elements on one or more edges may be defeatured out.”
Could you please tell me how I can resolve this? Though it shows the above error, a small portion of the domain is getting meshed properly.
Please find the image below, the geometry, where the domain with airfoil is getting meshed properly, where I thought the meshing will be complex and difficult.
