Ansys Learning Forum › Forums › Discuss Simulation › Electronics › Ansys HFSS transient near field data extraction › Reply To: Ansys HFSS transient near field data extraction
parksb2002
Thank you for your answer!
For 2 port(Rx,Tx) analysis, your suggestion is the best option I think. Thank you so much.
However I need not only the port to port analysis, but also I want to calculate the response of em field according to the input of antenna. Reason why I need this is I want to mimicing the EM field which calculated by external tool by adjust the antenna input signal. Can I get the frequency sweep response for EM field also? like S21 vs frequency plot.
Best,
S. Park
