Ansys Learning Forum › Forums › Discuss Simulation › Fluids › The total mass flow rate in DPM model › Reply To: The total mass flow rate in DPM model
luna6362
I expect that different DPM mass flow rates will result in different flow fields.
In reality, if I change the mass flow rate of the injected fluid, should the flow field be different?
I ran a steady DPM in a steady continuous phase.
If I change the DPM model to a transient type, will the results be more like what I imagine?
If so,what is the purpose of setting the total mass flow rate in the steady DPM model?
Thank you!!
