Ansys Learning Forum › Forums › Discuss Simulation › Preprocessing › CONVERTING STL FILE IN TO SOLID › Reply To: CONVERTING STL FILE IN TO SOLID
November 2, 2024 at 3:15 pm
I was able to open the .stl file in SpaceClaim and you also provided a .scdoc file of the same data.
Using the tools on the Facets tab, I am able to use the Auto Fix button and the Separate All button to divide the STL data into multiple bodies, then I deleted all but the main body. using Check Facets, there are two problems.
The question I have is if the Rhino 7 surface had these defects.
I have Rhino 7 and can open .3dm files. Can you provide the .3dm file also please?
