john.steele1
I am encountering this same exact issue. I will create a workbench file, save the file, and then close it. Then when I go to open it again it gives me the above errors.
Rajesjwari, I am not exactly sure what you mean when you say save the project under a different local drive instead of C and then try again, and the renaming of the Ansys folders. Is there any more description that could be given so that I can understand the solution better? Thank you.Â
