Ansys Learning Forum Forums Discuss Simulation Fluids Correct CFX Pre Setup to avoid isolated fluid regions Reply To: Correct CFX Pre Setup to avoid isolated fluid regions
Mark Owens
If the interior mussell region is a physical solid (as opposed to a geometrical solid) then you do not need a mesh for that unless you want to solve for the temperature inside the solid. In that case, you would create two domains in CFX-Pre. One fluid domain and one solid domain.
