Ansys Learning Forum › Forums › Discuss Simulation › Fluids › Correct CFX Pre Setup to avoid isolated fluid regions › Reply To: Correct CFX Pre Setup to avoid isolated fluid regions
Kelsey O'Donnell
Hi Mark,
I am able to do this and there is simply a check next to connections in the mesher but no connections present. My concern, however, is that I am trying to enclose hundreds of individual solids to simulate flow through a "mussel" aggregation, will doing this method instead of the enclosure cause a lot more computational power of this simply how I need to create it no matter what? Also does this work if I would like to have an internal volume as well? Should I simply be setting the outer box material to liquid? Sorry for all the questions!
