Ansys Learning Forum › Forums › Installation and Licensing › Ansys Products › AQWA: Hydrodynamic response error › Reply To: AQWA: Hydrodynamic response error
November 1, 2024 at 9:14 am
(1) Please check your reference article on the defintion of the reference degrees of freedoms for the stiffness matrix. Is the stiffness with respect to the motions at the ends of the connection points or with respect to the COGs of connecting structures?
(2) Please check the sign of the coefficients of the off-diagonal 6x6 matrices. I expect the values to be negative.
