Ansys Learning Forum Forums Discuss Simulation General Mechanical Tensile Failure in Ansys but not in reality related to preload Reply To: Tensile Failure in Ansys but not in reality related to preload
Pedram Samadian
Hi Aitor,
I see now. Is your bolt design finalized? I think the preload is too high. The bolted joints should be designed based on the proof strength/load of the bolt, which is the maximum strength/load that a bolt can withstand without acquiring a permanent (plastic) deformation. The proof strength is typically considered to be 85% of the yield strength, and the recommended preload is typically between 75 to 90% of the corresponding proof load. You may find useful information in the following video:
?start=448&end=587
You probably need to change the bolt design or modify the preload. I hope this works.
Thanks,
Pedram
