Ansys Learning Forum Forums Discuss Simulation Fluids LWF model not working on a coupled wall interface Reply To: LWF model not working on a coupled wall interface
milad.mahjoo
yes since the geometry is simple both cases are hex orthogonal mesh. Left image is not accurate as you've mentioned and its depicted just to show that the LWF works fine (even not accurate in this case) when case consists of only one zone. But the right one as it's obvious lacks any wall film formation process. So this is my main quastion: " Is non-conformal interfaces are limitation for Lagrangian wall film model utilization?" If Yes, I suggest to add this on Fluent's next version user's guide and what is the alternative suggestion to form wall films on such cases? If No, then what is the problem in this case?
