Ansys Learning Forum › Forums › Discuss Simulation › Fluids › Components of flow direction › Reply To: Components of flow direction
warhammer975
I found information that the radial component of the flow direction is zero, axial component Vx = V * cos(alpha) and a tangential component Vt = V * sin(alpha). V - is calculated through the flow rate and the flow area? But I still don't understand how to correctly determine the alpha angle?
