Ansys Learning Forum Forums Discuss Simulation LS Dyna Need some insights into contacts Reply To: Need some insights into contacts
Fernando Torres
Well, partially yes. Only difference between both questions is that this one hs solid top and bottom layers, while other has top and bottom layers made of shells (with a proper space allocated for the thickness of the shells)...
