Not splitting of bodies, you need to split the pipe surface.
Use the Split tool to generate the exposed and unexposed pipe regions.
Step 1: Select the pipe top face.
Step 2: Select the below option.
Step 3: Select the flange face.
Thanks,
Deepak
Please Login to Report Topic
Please Login to Share Feed
Edit Discussion
You are navigating away from the AIS Discovery experience
