Ansys Learning Forum Forums Discuss Simulation General Mechanical How to partition the pipe assembly? Reply To: How to partition the pipe assembly?
ErKo
Hi
Just use the shared toplogy in spaceclaim and as shown in the video I refered to in previous post – that will create all the face spilts and connect common faces so we get a connected mesh (and so we do not use contacts), and you will be able to select these faces you show. If you still want to split faces (but not merge common ones, so like what share top. does) use the split tool (you can use the flanges to split the outer pipe face):
https://www.youtube.com/watch?v=OPpwS66sciE
All the best
Erik
