Ansys Learning Forum › Forums › Discuss Simulation › Electronics › Deviating Simulation Results for different Box Sizes (ABC and FEBI) › Reply To: Deviating Simulation Results for different Box Sizes (ABC and FEBI)
dushyant.marathe
Hi Maximilian,
I think you should consider results for large box size 300 mm. Additionaly check the mesh on dieletric region and antennas geometry. If its corser you can apply
Manual mesh seeding operations for denser mesh. Look for number of adapative passes and converage criterion from solution data.
Inside Setup, you can apply additional convergence for S21, using Expression cache
Hope this helps.
Even if this does not help, submit a support ticket if you have access to Ansys Technical Support. Ansys support engineer can connect with you and help you out with settings. Thanks.
