Ansys Learning Forum › Forums › Discuss Simulation › General Mechanical › Meshing error ,(HELPPP) › Reply To: Meshing error ,(HELPPP)
muhammadagussriharto
Thanks for your response and I appreciated. Yes, maybe it's thin part from the size of hollow beam, (Length= 150000mm , width = 15000mm , Height= 15000mm, and thickness overall = 10 mm ). -  However , I still can't get it what you mean to fix it. what you mean by saying " use surfaces/shell and then use shell elements to mesh" and where to fix it , (at ansys spaceclaim or at ansys design modeler or at ansys discovery ) . Please tell me more detail about the solution . Thank you
Arton
