Ansys Learning Forum › Forums › Installation and Licensing › Ansys Products › Errors with multi-connected bodies using AQWA › Reply To: Errors with multi-connected bodies using AQWA
kholivt88
Here are a few troubleshooting steps you can try:
  1. Check Joint Connectivity: Ensure that all joints are correctly connected to the cables and that there are no overlapping elements that might cause conflicts.
  2. Review Cable Properties: Double-check the properties of your linear elastic cables. Make sure the material parameters are correctly defined and that they match the requirements for your simulation.
  3. Simplify the Model: If possible, simplify the model by temporarily removing some elements to isolate the issue. This can help identify if a specific part of the model is causing the error.
  4. Adjust Joint Types: While switching to a ball and socket joint can help, consider reverting to hinged joints for all connections if you encounter issues with other types.
  5. Consult Documentation: Refer to the software documentation or user forums for specific error messages. There might be known issues or recommended fixes related to your setup.
If these steps don't resolve the issue, providing more details about the specific error message might help in diagnosing the problem further. Good luck!
