Ansys Learning Forum Forums Discuss Simulation Optics Bloch boundry in movie monitor Reply To: Bloch boundry in movie monitor
Guilin Sun
I believe the movie result you observed is wrong, even though it has angle.
When source has angle theta not zero, in the angled plane you should use Bloch BCs. The result of magnitude is uniform, because it is plane wave. If you want to see the change of the wave form, you need to check the real or imaginary E, which has phase term included.
Please consider the physics of the results.
