Ansys Learning Forum Forums Installation and Licensing Ansys Products Ansys – Liscencing Problem Reply To: Ansys – Liscencing Problem
George Karnos
What is displayed if you open a DOS command prompt window and type in the following:
set A
Also:
ping license-ansys.eng.uci.edu
Do you still have ANSYS Student installed?
You can not have the student version and a version that connects to a license server installed at the same time.
If you had student installed on c:\program files and academic installed on e:\
I would uninstall all making sure to remove the Ansys inc directory on both c: and e:
(Make sure you did not save anything under those directories) after uninstalling, if they still exist,  you can rename them to .ansys.old to be safe.
