Ansys Learning Forum › Forums › Discuss Simulation › General Mechanical › Generation of constraint equation issues › Reply To: Generation of constraint equation issues
reddyramu.gundlooru
Hello Dlooman,
Thank you so much for your response. The problem was fixed when I created a new node at the same position as the intended node and used it for the MASS21 element instead of using the existing mesh node. But some new warning was raised when I created a superelement as you can see in the attached image. There are no issues with the DOFs of the master node but all the rotations DOFs are missing for the slave nodes.
master node is 70016
I have got one more problem during the import of the CREO Parametric part into APDL as you can see in the picture below.
If possible can you please help me with these issues?
Thank you and best regards
Reddyramu Gundlooru
