Ansys Learning Forum Forums Installation and Licensing Ansys Products How to get the rotations of each node in a plate modeled through solid elements? Reply To: How to get the rotations of each node in a plate modeled through solid elements?
dlooman
You can create a remote point at locations where you want to know the rotation.  The remote point is a node with rotational dof.  It may help to later if you give the remote point pilot node and APDL name in the details.  This "name" is an APDL  parameter with the value of the node number.
