Ansys Learning Forum › Forums › Discuss Simulation › Fluids › Modeling the acoustic radiation force on a particle, discrete phase model › Reply To: Modeling the acoustic radiation force on a particle, discrete phase model
October 30, 2024 at 1:18 pm
You may want to explore interpolation files for Fluent combined with User Defined Memory. That may be an easier way of getting the results out of Mechanical. The UDF then uses the UDM plus whatever else you want/need from the data.
