Ansys Learning Forum › Forums › Discuss Simulation › Fluids › Node 13: Process 21060: Received signal SIGSEGV › Reply To: Node 13: Process 21060: Received signal SIGSEGV
It’s not an installation issue. Check the mesh quality but also the number of cells on each partition. The solver passes data between nodes but if there are too many partitions (ie too few cells per node) there can be problems: it’s rare but with a 2d mesh quite possible.
Student is 4 cores, a research licence with parallel will get you more. I’m a little unsure quite what as the bundles differ with some releases and Academic keys may also be different.
