Ansys Learning Forum › Forums › Discuss Simulation › Fluids › Saving report value to a variable using TUI commands in Fluent › Reply To: Saving report value to a variable using TUI commands in Fluent
wheeler.ky
Hi, thank you for the response!
I am able to write the value to a file, but I'm looking to save the value of the report to a variable that I have defined in the script so I can perform some logic based off of the value. Do you know if there is a way to do that?
Thanks,
Kyle
