Ansys Learning Forum › Forums › Installation and Licensing › Ansys Products › error coincident nodes problem in Ansys Aqwa › Reply To: error coincident nodes problem in Ansys Aqwa
Pedram Samadian
No problem. I would suggest finding those elements using their ids. In this way, you can see if you need to merge the nodes or to adjust the node positions to ensure they are distinct.
Thanks,
Pedram
