Ansys Learning Forum Forums Discuss Simulation Fluids CHT Simulation Using VOF Model (Steady-State) Reply To: CHT Simulation Using VOF Model (Steady-State)
fyoussef
There is no heat transfer from the solid, as I have already checked. If there were any way for heat to leave the solid, it should also occur when I run the same simulation with a single phase—unless I’m misunderstanding something. This is a steady-state simulation, running for over 2400 iterations.
