Ansys Learning Forum › Forums › Discuss Simulation › Fluids › CHT Simulation Using VOF Model (Steady-State) › Reply To: CHT Simulation Using VOF Model (Steady-State)
fyoussef
As you can see in the lower region, there’s almost no temperature gradient—ΔT here is less than 0.5°C, which is for a steady State simulation negligible. While the cylinder’s temperature is around 60°C, the fluid temperature remains at its initial level of about 27°C.
