Ansys Learning Forum › Forums › Discuss Simulation › Fluids › Thermal Analysis of Sealed Cabinet › Reply To: Thermal Analysis of Sealed Cabinet
October 29, 2024 at 4:49 pm
Thanks for contacting us. When you encounter memory issues in LS-DYNA, especially with limited memory resources, there are several ways to optimize your simulation for more efficient memory use, which are outlined below:
– Reduce the Element Count
- Mesh Optimization: Use a coarser mesh in regions where high accuracy is not crucial and apply a finer mesh only in areas of interest (e.g., stress concentration zones). This reduces the memory needed to store and compute element data.
– Use a Single Precision Version of LS-DYNA
- Single Precision Solver: Run the solver in single precision if double precision isn’t required for your application. Single precision uses half the memory of double precision and can still yield good results, especially for non-high-accuracy simulations.
– Optimize Contact Definitions
- Simplify Contact Types: Use simpler contact definitions where possible. For instance, *CONTACT_AUTOMATIC_SINGLE_SURFACE consumes more memory than *CONTACT_AUTOMATIC_SURFACE_TO_SURFACE. Only use the former if absolutely necessary.
– Reduce Output Frequency
- Database Output: Lower the output frequency of results files like D3PLOT and GLSTAT, which consume a lot of memory and disk space. For example, change from every 0.1 ms to every 1 ms if appropriate.
- Selective Output: Disable unnecessary outputs, or only save variables critical to the analysis. For example, avoid saving stress and strain at every time step if they are not essential.
– Run on Fewer Processors
- Processor Adjustment: Running on too many processors with limited memory can lead to memory fragmentation and increased demands. Try reducing the number of processors to optimize memory use, especially on machines with limited cores and RAM.
– Simplify Element Types
- Switch to Simpler Elements: If your model allows, use simpler elements (e.g., reduce higher-order elements to linear elements) to cut down on memory use.
If you continue to experience difficulties, it may be beneficial to consult the LS-DYNA user documentation or reach out to Ansys support for more targeted advice on managing memory usage for your specific simulation scenario.
Thanks,
Pedram
