Ansys Learning Forum › Forums › Discuss Simulation › Fluids › Can we change the value of parameter used in the wave spectrum equation (Fluent) › Reply To: Can we change the value of parameter used in the wave spectrum equation (Fluent)
Yes, but only by adjusting the variables in the panel via a UDF or (possibly) an Expression.
It may be possible to completely replicate the boundary using a UDF but that will be very non-trivial as the open channel is a special case in Fluent regarding phase assignments.
