Ansys Learning Forum Forums Discuss Simulation Fluids BAD TERMINATION in Fluent when apply profile data to boundary Reply To: BAD TERMINATION in Fluent when apply profile data to boundary
What is the x-position range on the boundary? If you use contours & pick the surface with global range & node values off you should see the min & max values.
