Ansys Learning Forum Forums Installation and Licensing Ansys Products ANSYS Fluent Meshing: “tgrid process could not be started” Reply To: ANSYS Fluent Meshing: “tgrid process could not be started”
alexander.osters
Hi, sure.
Alle Advanced Options are on default. Just the Check Self Proximity is set to yes and Quality Warning from 0.05 to 0.1.
Normally the min cell lenght ist set to 1.
Also the mesh should be in the recommended mesh qualtiy criterias, as the Skewness is below 0.7 and Aspect Ratio below 1000 with double precision on.
