Ansys Learning Forum › Forums › Installation and Licensing › Ansys Products › ANSYS Fluent Meshing: “tgrid process could not be started” › Reply To: ANSYS Fluent Meshing: “tgrid process could not be started”
Federico
Can you show your settings for your Volume Mesh task?
Rough rule of thumb is that you need ~1Gb of RAM available per 1M cells, slightly more or less depending on the cell type.
