Ansys Learning Forum › Forums › Discuss Simulation › Photonics › Trapezoidal ring › Reply To: Trapezoidal ring
rahul.sanghvi
Hi Kirill,
Do you know how to modify the code for 90-degree bend waveguide such that it creates a waveguide of an arbitrary angle instead of 90 deg?
# 90 degree waveguide bend
# This object makes a 90-degree waveguide bend with angled sidewalls.
# Input properties
# base angle: sidewall angle of the waveguide
# base height: height of the waveguide
# base width: width of the waveguide base
# radius: radius of the bend
# start angle: start angle of the waveguide
# Tags: integrated optics waveguide bend 90 degrees ridge
# Copyright 2015 Lumerical Solutions Inc
# simplify variable names by removing spaces
base_angle = %base angle%;
base_width = %base width%;
base_height = %base height%;
start_angle = %start angle%;
select("arc");
set("material",material);
set("base angle",base_angle);
set("base height",base_height);
set("base width",base_width);
set("detail",0.5);
# magic number
# The cubic Bezier curve using this magic number in the pole points approximates the semi-circile with least error
m=0.55191502449;
px = radius*[0;m;1;1];
py = radius*[1;1;m;0];
p = [px,py];
set("poles",p);
set("first axis",'z');
set("rotation 1",start_angle);
