Ansys Learning Forum › Forums › Discuss Simulation › Fluids › Saving report value to a variable using TUI commands in Fluent › Reply To: Saving report value to a variable using TUI commands in Fluent
October 29, 2024 at 8:30 am
You can write the value to a file using TUI command:
/report/surface-integrals> area
(inlet)
Surface Id :(1) ["inlet"]
Surface Id :(2) [()]
Write to file? [no] yes
filename (*.srp) [""] test
