Ansys Learning Forum Forums Discuss Simulation Fluids MSMD Battery model, UDS diffusivity option is not there Reply To: MSMD Battery model, UDS diffusivity option is not there
Murari Iyengar
Hi, you can find UDS Diffusivity under Fluid Material Properties. Set it to 'defined-per-uds' and click on Edit. You will get the pop-up to enter UDS Diffusion Coefficients.
