Ansys Learning Forum › Forums › Discuss Simulation › Fluids › Problem when simulating a battery pack with multiple parallel battery connection › Reply To: Problem when simulating a battery pack with multiple parallel battery connection
October 29, 2024 at 5:08 am
Murari Iyengar
Hi, there are a few things you need to check starting with the Battery Model parameters. You also need to check the Material Properties including the thermal conductivity values which will have orthotropic conductivity for cylindrical cells. You can see 31.2. Using the MSMD-Based Battery Models for more information on the NTGK model. You can refer the NTGK model tutorial here: Chapter 32: Simulating a 1P3S Battery Pack Using the Battery Model
