Ansys Learning Forum › Forums › Discuss Simulation › Photonics › Creating a polygon with tilted sidewalls via python API › Reply To: Creating a polygon with tilted sidewalls via python API
Kirill
Hello Matthias,
It seems you are not able to complete the layer setting with
mode.set("geometry", {"1:0": vertices})
Try to use
mode.set("geometry", {"1:0": [vertices]})
instead and see if it helps.
Also, since you're calculating the vertices yourself, you can pass them directly to the LayerBuilder without the need to create an extruded polygon.
Best regards,
Kirill
