Ansys Learning Forum › Forums › Discuss Simulation › Fluids › Problem with the coupling of ANSYS Fluent and Rocky DEM using a UDF › Reply To: Problem with the coupling of ANSYS Fluent and Rocky DEM using a UDF
October 28, 2024 at 4:07 pm
Hi Victor,
Thank you so much for your feedback.
It is about a DEFINE_PROPERTY. I am trying to model a magnetorheological fluid whose properties, especially viscosity, can be changed under the influence of a magnetic field. I followed the steps you recommended, but I got an error message saying that Ansys needs a C++ compiler. I will look into fixing this error message and go through the steps again. I will keep you posted on the outcome.
I also have a question: Is it possible to implement the magnetic field using the MHD model?
