Ansys Learning Forum › Forums › Discuss Simulation › General Mechanical › Stress Display for Top/Bottom is Not Matching with Individual ‘Top’ Surface › Reply To: Stress Display for Top/Bottom is Not Matching with Individual ‘Top’ Surface
Thanks for the reply.
I usually use Unaveraged Stress results, and that is where you get the same results for Top/Bottom and Top.
I learned that there is a huge difference for Elemental Mean, which I almost never use.
Here are the results of the default setting of Averaged.
 I recommend you use either the default Averaged or my favorite Unaveraged stress results so you don’t have to worry about the Top/Bottom distinction.
Note that the stress in the Unaveraged element will approach the Averaged stress as the element size gets smaller.
