Ansys Learning Forum Forums Discuss Simulation General Mechanical Honeycomb Shear modulus Calculation based on Analysis – ASTM 273 Reply To: Honeycomb Shear modulus Calculation based on Analysis – ASTM 273
Can Ozturk
In light of what we talked about the analysis model, I see that the model setup and assumptions I made match with yours. But the modulus is 100 MPa different as a result. Could you please review the model if I add it here on Wednesday? Maybe I'm missing something. I set up the model in ansys 2020 r1. But if there is a version problem, I can only add the geometry and share screenshots of my setups here.
