Ansys Learning Forum Forums Discuss Simulation 3D Design Substract shape from two other shapes Reply To: Substract shape from two other shapes
Dato
Hello, I'm facing a similar problem. I am trying to having a solid body from .stl file to mesh. Are your irregualr solid geometry from .stl file? Do you directly convert the facet body to solid body in SpaceClaim? I found that convert to solid body is time-consuming. Thanks!
