Ansys Learning Forum Forums Discuss Simulation Photonics MQW structure auto-populating in CHARGE Reply To: MQW structure auto-populating in CHARGE
kghaffari
Thanks for your questions:
  • The paritioning in CHARGE:MQW can be edited. To do this go to advanced settings (under CHARGE:MQW:Advanced), and enable the override partition table option. Please take note of the displayed warning regarding number of quantum wells per partition. I agree that the partitions should be defined/populated at barriers, so hopefully this can allow you to make the needed correction.
  • Regarding the auto-population, this can not be disabled in CHARGE and is automatically read from the MQW domain.
  • For the thickness defined and what’s shown in this table, I notice the same behavior exists in our published example here, where the outer barriers are shown as 0.02 micron and not the thickness manually defined. I think this value may not be important as these are the most outer layers, and may be considered infinite barrier. I will double check this with our team internally, and let you know if I have any updates. Do you see such discrepancy in other layers as well (aside from the first and last layer in the table)?
Thanks
