Ansys Learning Forum › Forums › Discuss Simulation › LS Dyna › Fluid-structure interaction coupling › Reply To: Fluid-structure interaction coupling
October 25, 2024 at 6:24 pm
Hi Ian,
I left the NID and EID values as defaults which set them automatically above their maximum numbers. Is it okay with you to take a look at the k file? That way we can reduce lots of back and forth communications and I can post the debugging finding here afterward for the community.
Mamun
