Ansys Learning Forum › Forums › Discuss Simulation › Fluids › Error Opening Rocky Projects › Reply To: Error Opening Rocky Projects
w.p.goh
Hello Jackson. It should be version 23.1.0. It was a version I used when Rocky was still not part of Ansys.
I don't have access to the previous version of Rocky anymore as the license has expired and hence can't try what you suggested.
I did try to remove the simulation folder but the problem persists.
Ideally, I would like to be able to open those simulations again and do some post analysis as I have the simulated results. However, I also acknowledge the technical difficulty here regarding the compatibility issue. It may not be something easy to fix. What I am really after is to find out what input parameters (material properties, interactions, etc.) that I used in those simulations. Is there any way to extract these information without opening the projects in Rocky?
Thanks.
