Ansys Learning Forum Forums Discuss Simulation Fluids two interraction body in AQWA Reply To: two interraction body in AQWA
Nese.Halilbese
Thank you so much,
I suspress the fenders.I got results like;
for the cylinder
for the piston;
I think the result is correct for the cylinder but for the piston its not. I dont want to use mooring lines because in the actual model there is no mooring lines. In the actual model, the piston is located inside the cylinder and it moves up and down by itself with different speed. What I am trying the show is the cylinder and piston will move with different speed.
