Ansys Learning Forum › Forums › Discuss Simulation › LS Dyna › Fluid-structure interaction coupling › Reply To: Fluid-structure interaction coupling
Ian Do
Hi Maman,
I m away to a conference. Will be back tomorrow..make sure you offset the beginning nid & eid to values above the max already occupied by the lag sstructures.
vol fill:
use segment set oc box that fits the volume you want to fill.
