Ansys Learning Forum › Forums › Discuss Simulation › Preprocessing › the matrix T in the cyclic symmetric formula!! › Reply To: the matrix T in the cyclic symmetric formula!!
Shashidhar Reddy
Need your help to understand the query clearly.
Can you please let me know the final objective here?
Are you using mechanical or APDL?
Are you trying to simulate Modal cyclic symmetry analysis with coriolis effect on?
If yes, the following example may be useful.
Ansys help -> MAPDL ->Cyclic symmetry analysis guide ->Example cyclic symmetry analyses ->5.8. Example Rotating Cyclic Symmetry Modal Analysis with Coriolis Effects
You have mentioned that "damping cannot be used in cyclic symmetry", Are you trying to mention about the cyclic symmetry harmonic analysis?
Please let me know.
